Noob with a problem
Discussion in 'Motorized Bicycle General Discussion' started by joabthebugman, Jul 16, 2010.
  1. joabthebugman
    joabthebugman New Member
    Jun 21, 2010
    347
    I bought a used Gary Fisher mountain bike with a Skyhawk motor and a broken chain for $100
    The motor supposedly ran and I figured for the price I at least had a good bike and a bucket full or kit parts
    The problem I'm am having is that the motor seems to have compression only half the time
    When I first tried to start it I would pedal and sometimes I would get good compression and it sounded like it would start, and sometimes it had nothing
    I put it on a stand and pedaled by hand with the clutch engaged
    Half a sprocket worth of turning had compression and half did not
    Any ideas, or am I looking at the wrong thing
  2. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Might look in the clutch side(water drop shape)and see if the little gear is cracked or there is some metal powder(shavings) around the small gear,,,If the motor is on the bike and the clutch handle works ,you mightlock the handle and adjust the flower nut(clutch adj.)while the cover is off
  3. Creative Engineering
    Sep 20, 2008
    1,668
    You sir...have a long road ahead of you! From reading your post, it is impossible to diagnose what is going on!
    Once a bike is run-in a bit, I can stand beside it, lift the rear wheel, and kick start it with the pedals...by hand, not a chance!
    Jim
  4. joabthebugman
    Jun 21, 2010
    347
    No no
    Wasn't trying to kick it over by hand
    just checking the compression issue
    I noticed the on again off again compression issue while I was trying to pedal it off
  5. Bikeguy Joe
    Jan 8, 2008
    11,529
    Sounds like the clutch was slipping?
    You can't have part time compression.
  6. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    Actually, you can. I haven't expereinced it on these motors, but when a motor becomes really crap, once they're warm there's basically no compression, but for a cold start they're fine.
  7. joabthebugman
    Jun 21, 2010
    347
    Haven't had time to work on anything yet, but I will check the clutch tomorrow
    If that doesn't do it I'll just buy another motor kit
    I'm gonna need some of the parts for my grand daughter's bike anyway
  8. Dougan
    Dougan New Member
    Apr 5, 2010
    78
    Has to be the clutch.
    Easy to find out too. Just take teh cover off of the clutch and do what you were doing. See if both gears are always moving.
