No throttle response at Low End
Discussion in 'Motorized Bicycle Trouble Shooting' started by alumaline, Oct 3, 2014.
Tags:
  1. alumaline
    alumaline New Member
    Mar 21, 2014
    My China girl engine has terrible low end throttle response. The RT carb is way better than the stock carb but low end is so bad if I don't constantly rev the motor it dies. Sometimes when the motor is hot it will run at high rpm without me reving motor. A cold motor with full choke has a reliable idle.
    I tried Al Fishermans engine trouble shooting ideas, which helped a little but no fix.
    Thanks in advance.
    Mark S.
  2. Slogger
    Slogger Member
    Sep 8, 2014
    545
    "Sometimes when the motor is hot it will run at high rpm without me reving motor." = revving with the throttle closed- This makes me think air leak.
    I would check the manifold to carb junction and the manifold to cylinder connection, too. Also check the carb slide is moving smoothly as the throttle is twisted.
    Just a first impression.
    Good luck!
  3. crassius
    crassius Well-Known Member
    Sep 30, 2012
    4,032
    153
    yeah, sounds like air leak
