Al.Fisherman
Ok, tore down the whole thing, lower end.
I need to actually remove the two wheels that hold the rod in place, in order to access the damaged aluminum on the threaded intake.
How do I remove the actual two wheels that hold the rod in place?Chris B.
Once all the exterior screws, bolts, and nuts are removed the only thing holding the crank in the case will be the bearings and seals. The crank and rod should pull out in as a unit. Might have to use a little persuasion....leather/rubber hammer. Can be done with a light weight hammer with a block of soft wood (tap the crankshaft out of the case). If you noticed in the pictures I split the case apart. After hardware was removed, the only things that were holding the two case halves together was the bearings and seals. That is one picture that I didn't get....the crankshaft laying on the bench.
Photobucket... Thanks Rusty.
