Next build old indian
58er
59
6
Michigan
Finally time to start next bike.
For this one I bought frame/engine kit from Sportsman Flyer.
Very good company to deal with.
Going for 1910 (or so) Indian single with barn find patina.
next up is bending handlebars and making front end.
Haven't had much time to work on it so it may be a while ...
Sportsman kit is top notch
  • Like
Reactions: Nightster
58er
59
6
Michigan
Just some 20 gauge metal plasma cut for the head.
The bottom part ( trans case ) is the same gauge. Rolled and fitted.
Just meant to dress up motor a little.
58er
59
6
Michigan
Eventually I will make one similar to the first bike I built.
But for now I wil use a monarch springer due to lack of time and wanting to finish it.
Gbrebes
656
260
Los angeles
Your bike is top notch on the vintage tip.
I really like the front fender. Did you hand-bead that piece? If so, how did you do that? Did you add on thin rod, or did you run it through a beading contraption?
Anyway, super authentic patina, you should be proud.
Gilbert
indian22
4,734
7,740
Oklahoma
Gilbert that's a sheet metal bead roller in the background of his number 5 photo & the fender shows he's pretty good with it! Rick C.
58er
59
6
Michigan
Thanks for the nice words. I will post pictures of the bead roller, really not as good with the bead roller as the pictures lead to believe..... must be the rust on the fender....
indian22
4,734
7,740
Oklahoma
Modest as well, decorative iron work on the front of your shop was a giveaway to a metal worker...and not everyone has an English wheel sitting next to a bead roller. both show intent to work sheet metal. Just a nosy old guy's passing observations. Build on. It's all good! Rick C.
