Prof Fate
I got my new slant head but am having trouble mounting it. With the extra gaskets, the amount of bolt protruding though the head is barely enough to screw on the acorn nuts. I used 3 of the thin paper gaskets at the bottom and 1 metal on the head to keep the piston from hitting it. But the combination of the 4 gaskets and the possibly thicker head, the 8m bolts that come though the head are now really too short to properly tighten down the acorn nuts. I removed a washer from each bolt leaving only a lock washer and the nut but I am barley able to get enough revolutions on the nut to consider them secure. Was this an issue for any one else? I tried my local Ace hardware store but they didn’t have that size all thread. Any suggestions? They are the 8m-1.0.
I did tighten then enough for a brief test run. Its running pretty bad but I haven’t tried adjusting the carburetor yet. I did take the opportunity to port the intake and exhaust while the bike was out of commission. I did as little as possible and only removed sharp edges from the casting. I did remove quite a bit of material on the pipe from the carb to the intake to try and enlarge it to match up better. I am planning on buying SBP expansion chamber pipe when they are back in stock. Should I wait till I install the pipe to try and tune it or will making it run better now make it easier to adjust with the new pipe?
