stevolandis
Hello everyone- I just bought a hd shift kit(the new version) from SBP. Of course, I had problems.
First of all, I have a standard american bike, nothing special or custom.
The installation went wonderful, but when I first rode it, It went well until a higher gear. Then, the chain popped off, and after putting it back on, it popped again, this time breaking.
While fixin' the chain, we noticed the bearing plate was bent. We fixed that, put everything back together, aligned and tightened the chains, and tested it again. Guess what happened? The chain snapped again. Believe it or not, I was gettin' just a tad frustrated.
We redid everything, and noticed something funny- the engine chain was getting really tight for some reason. We loosened it by grinding the engine down a bit, and reattached everything. It got tight sometimes, and loose sometimes- I think when tightening down the engine, something changes the chain tension.
Today, I took off the right crank, put longer bolts in the two lower sprockets, and had it spaced with two nuts(one more nut than normal). It rides like a normal bike, so at least the bottom end of the kit is working. But when I went to put on the jackshaft chain, I lost the masterlink clip- of course. But, I could tell that in higher gear, the chains will be 2-3mm apart.
Hopefully tomorrow, I'll get that chain on, and see how things run. If anyone could enlighten me about these befuddling problems, I'd be mighty happy!!
Thanks a bunch!!
Thanks a bunch!!
