New Recumbent Build
]have started on the seat brace clamp. Used a piece of tubing with an id the same as the od of the aluminum rod that will be the back brace. Used 4 barrel nuts and ground a concave on one side of each one. Blazed the nuts to the tube. Now have to split the clamp lengthwise and braze to the seat rail.
Elmo
And one more clamp.
Made these from 1"X1" aluminum bar stock.
Elmo
Can anyone tell me why I can only have one attachment per post?
Thanks SB. I have to order some phifertex mesh fabric in royal blue and get my brother the part time upholsterer to sew up the seat fabric. I add grommets along the sides and lace it on with nylon (small) rope. This smooths out the bumps very well. I found a picture on the web that gives me some ideas for the paint job.
Elmo
A comfortable seat for cruising is a big deal, I think. More so as we get older. Looks like yours would be comfy enough to nap in... or do a little fishing at the end of a dock... (lock the brakes) ha!
SB
This trike that I built would be the one to fish from if I could figure out how to put a Greyhound on!image.jpg
SB
I have put in some 50 mile rides on my pedal bike only thing that hurt a little was my legs!
Elmo
I made the front motor mount today. I have a 3/8" plate mounted to the engine bottom and it will be bolted to this mount.image.jpg
Building a motor bike from scratch sure takes a lot of time!
Elmo
I built the rear motor mount today and mounted the engine. What do you know they fit like a glove. I bolted the blocks together and step drilled from 1/8" to 7/8" and used an adjustable reamer for final fit. The tubing was about .010 larger than 7/8". The reamer was for the kingpin bushings on my 1954 F100 pickup. Now I have to mount a gas tank, rig up an exhaust and get the jack shaft lined up. Then I can see how it shifts gears! It will be nice to have seven choices for gears. The low gear ought to climb a tree if I could get traction. My cassette has a 34 tooth low cog.
Elmo
