I've been getting quite a bit of prep work done the last few days. I took my clutch lever from my china kit and made a spring return for it so that I can still use it to control my brake light. I found an axle that is long enough for the motorcycle forks, though I'm missing some of the lock nuts for the cones, but I believe those can be found easily enough. I cut one of the fork dropouts today (they're motorcycle forks, so they don't have open dropouts like bicycle forks, I guess motorcycle hubs must typically have sealed bearings and you can slide the axle through). I'm going to cut the other one in the next day or so. I got new bearings for the Cranbrook rear wheel, and also put some zip ties where the spokes cross to prevent them from flexing too much. I should be able to get this bike up to a rolling chassis very soon. I also shimmed up my head tube. The forks I got have a 1" steerer tube (1" steerer tube on mc forks, go figure lol), and the Schwinn frame I got apparently has a 1&1/8" head tube, so what I did was take two pieces of sheetmetal for each bearing cup and bent them to make them form a round shape, and left gaps between the ends so I could compress them into the head tube. It worked very well, and I know my fork can be bolted on safely. I use 3 nuts on the headset, the cone nut first, then a flat washer, then a flat nut, then a crown nut which I've cut the crown part off of. Plus the top tree bolts to the steerer tube, so my forks arent going anywhere lol. I still have a fair amount of prep work to do, but tomorrow I need to start cleaning up the basement.
