Shan,
I think Dave was talking about EMT, conduit. Not flex. Flexible conduit will leak badly. It won't contain liquids or gasses.
3/4" EMT lends itself nicely to custom exhaust systems. It can be bent and welded, or brazed, and is light and, if you feel so inclined, can be polished to look almost as good as chrome. It doesn't hold the shine permanently but once buffed the shine can be brought back with just a little elbow grease and metal polish. I use TIG to weld it and a conduit bender to make those swoopy curvy bends. He also mentions the pre-bent sections. Usually they have a tighter bend radius than you can get with a bender.
Watertite flexible conduit works just fine to contain liquids or gasses.Shan,
Just strip off the plastic coating and the inside is pretty smooth.
Stainless steel flexible conduit bends tighter, is stronger and was used
on the original Whizzers for their exhaust tubing capped with a fan tail tip.
Gas line flexible tubing has corrugations that would not be good for exhaust flow.
Im going to look into.the conduit. My engine seems to.be.running hot. Ive only had it.for maybe a month. Could it be the warmer weather?
"Weathertite" flexible conduit is made of steel and the plastic coating is on the outside.How do you plan on attaching weathertite conduit to anything with the plastic coating on the inside? Welding it? Yes it might hold liquid and gas but it's stainless steel. You can't solder it, you can't braze it and only those with skills could weld it and then there goes the coating so you have a leak.
I totally agree it would be a epic fail to a otherwise what could but will now never be a perfectly ''tuned'' expansion chamber. IMO.Gas line flexible tubing has corrugations that would not be good for exhaust flow.
Have you tried filling the emit with sand and packing it in tight before bending? Or does it still try to smash flat when bending?
I haven't tried to bend any small tubing on my new HF pipe bender but I did get a successful bend on some 1 1/2" steel pipe by bending it the desired angle then taking the pipe to the press to push the bent section down to where its even with the rest of the pipe, still not as nice as a mandrel bend but nicer than just bending it in the bender, I still need to get a few bags of sand to see if filling the pipe with sand will help keep it round at the bend.
I first saw Cerro-Bend used in the Air Force. They had it in a vat submerged under boiling water. The technician would dip the tubing under the surface of the Cerro-Bend, filling the tube then submerge it in cold water. The tubing was then placed in a computerized bender that put the precise bend and angles in the pipe and then it was again submerged in the hot tank where the alloy melted and ran out leaving a prefectly bent tube.Yup... that Cerro Bend stuff is the best thing to use if one can get it in the right amount to fill the pipe to be bent... I've seen that stuff before and it basically turns a tube into a solid piece until you melt the stuff out, and it can be reused over and over. I've heard some of these super low melt alloys can get ruined if they are heated too hot and it will raise the melting point beyond an easily usable temperature. Not so sure if that holds true for the Cerro Bend stuff or if it's just certain alloys designed to melt at or below 200F...
