mapbike
How do you find out the chain size and the type of engine? It said 80cc. How fast can you go in the very beginning of an engines break in period?
The reason I ask about type/brand of engine is because I remember seeing some of the Grubee engines listed as having the 410/ standard bicycle size chain, is the chain for the engine the same width as the chain on the pedal side of the bike?
If it is the same size then it is the 410 size chain if it is wider than the chain on the pedal side it is the 415 size chain which most of the kits have now days.
On a stock unbroken in engine running a 44T rear sprocket you should have a cruise speed of 20+ mph, don't push it and over rev the engine until you have run at least 2-3 full tanks of fuel through it.
Map
