Narrower chain?
Discussion in 'Motorized Bicycle General Discussion' started by toker_ace, May 4, 2009.
  1. toker_ace
    toker_ace Member
    Oct 15, 2008
    475
    Does anyone know where and what kind on chain I can run on this occ chopper (look-alike) that is narrower? the chains that come with these kits is wide and there isn't much room between the chain and the tire. I think the size of the chains are overkill anyways. thanks
  2. RedB66
    RedB66 New Member
    Dec 28, 2007
    1,023
  3. toker_ace
    toker_ace Member
    Oct 15, 2008
    475
    I ordered the grubee 66cc. Will it work on it? I would think that all the front sprockets are the same???
    #3 toker_ace, May 4, 2009
  4. Retmachinist
    Retmachinist New Member
    Oct 21, 2008
    637
    The HD single speed bicycle chain is even to narrow. The kit sprockets vary in width but are at least 5/32 wide. It is always possible to face off the sprockets to 1/8" wide, but it wouldn't be worth it for no more than you would actually gain in width.
    I have often thought about #35 chain, but there again it wouldn't be worth the hassel of trying to find, and do the machine work that would be needed to adapt the sprockets.
    John
  5. spad4me
    spad4me New Member
    Jan 20, 2008
    472
    Thats Dax sells a .81 thick drive sprocket.
    Using his is easier than grinding the sides of the drive sprocket down to fit a BMX chain.
    Most install's require grinding down of the rear sprocket to even use 415 chain.
    I am planing on a occ chopper hapytime build soon.
    Use a BMX chain
