My first race bike build!!!
My cvt belt get eaten up. Im trying to see if my cvt can handle this motor. I remember seeing something about changing out the spring in the cvt. I think my cvt only handles 3200 rpm. Im not use is thats good enough
Sounds like you still need to jet up another size if you can feel it speeding up when you back off the throttle, at full throttle the main jet is wide open so it can only flow the amount of fuel it was drilled for. If you have a set of small drill bits you can run the bits thru to see which one fits it exactly then drill it out with the next smaller Number bit which is the next larger size. I prefer to just buy more jets and keep a few sizes bigger and smaller to make future adjustments quick and easy, but you can also drill them if you got the right bits.
The CVT may eat a belt or 3 while it's breaking in as well because those surfaces need to be really really smooth that the belt rides on and as the belt polishes the sides of the sheaves it'll stop eating belts... I used to buy 3 or 4 belts at a time for my go kart when I had it because it can eat belts, but shouldn't eat a belt in just a few rides. make sure you don't have any burrs or deep gouges or scratches in the belt sheaves where they contact the belt and polish out any imperfections on the riding surfaces, and also make sure the flat sides of both sheaves are lined up as perfectly as possible.
Had a extra belt slaped it on. Throttle doing the same thing. Ill try to drill them out and see if this will adress the issue. Oh and love the brake, but it seems to need ajust ment after a nice long run.
Keep playing with your top end fuel mixture, you'll feel it go faster as you jet bigger, then it'll reach a point where it feels dull and not quite as quick on top, that's where you back off one size with the main jet, you may also feel a slight hesitation before the engine responds when the main jet is too rich.
From what it sounds like you got the jetting close, maybe one or 2 sizes up on the main and it'll be there... you'll still need to play with the needle settings tho so when you go up in jet size, put the needle back in the middle until you get the top end to do what you want, then adjust the needle if needed after you get the top end dialed in.
Before you order that head, contact rogerdendron1 who is also a member in here that knows a lot about these type engines, he may have the head you need as well as other goodies that can save you a few bucks. He's told me in some other posts that he knows these engines really well so it might be worth asking him both for advice and for parts he might have left over...
Yea. Just need a good pair of spring. Tried to dial in the carb today could not do it. Thts a two man job lol. I cut my manifold shorter so now its harder to get to my fuel/air srew. I need to figure out how to dial it in perfect. I have a race coming on Sunday
This may look like a bandaid fix, or you could look at it as a tuning aid for varying weather and track conditions, but I use one of these on my Harley and it does help to keep me out of the inside of the carb... http://www.thunderproducts.com/dial_a_jet.htm
The way these work is by feeding the extra fuel only when needed by sensing engine load and controlled by a small dial with small air bleeds in different sizes, but the way it works is you jet the carb a size or 2 lean then set up the dial a jet so it lets you change settings pretty much on the fly, or at least without the need to open up the carb and it basically takes over where the main jet leaves off, even as simple as these are, they are really good at keeping the air fuel mix spot on.
Mikuni makes one similar called the power jet which works about the same way but to make adjustments it requires changing the internal jet and it just feeds raw fuel at a predetermined rate with no air bleed to compensate or keep the fuel metered accurately by it's self.
I'm thinking this may help you once you get the tuning close since it allows you to adjust without removing the carb or float bowl, you'll still have to do that to get the carb dialed in initially, but these will help afterwards.
For now, I'd say go up at least one more main jet size and it should pull better at higher rpm.
I think i will be changing out my head on this motor. Here is the info on the head...
Professionally race prepped JT136 head assembly ($52.50)
Spring height adjusted to*.816" IN/ .817" EX and the valves are lapped.
Chamber depth of .294"
Ive desided to redesign a few things on my bike. Here is what iam aiming for
12 tooth clutch will give you a faster take-off and lower gearing for climbing
13 tooth clutch will give you more top end speed
So which one should I get?
No hills where i live just flat urban streets
