the first thing I'd suggest is s clutch reset. First undo the cable at the lever on the right side you dont have to pull the cable out just have it free, next remove the right side clutch cover remove the set screw then remove the flower nut.take the steel clutch pad off remeber there is a sping in there Now set the arm to just where pressure starts and tighten it down. back the right side stretch the spring just a litte then put the spring back in place then the steel pad, push in on the pad and put the flower nut hand tight, then go 3 notches tighter of where the set screw goes and you should be very close on it, i generally use needle nose pliers to turn the flower nut. Of course thats for a 2stroke if its a 4stroke i dont know ...happy trails
