mounting stud removal
Discussion in 'Motorized Bicycle General Discussion' started by Indybiker, Apr 10, 2010.
  1. Indybiker
    Indybiker New Member
    Mar 9, 2010
    8
    I am having an issue with the front mounting studs. I am using the adapter plate and a u bolt, and cut the studs down. But there still hitting the down tube. My question is how difficult is it to remove the studs and use socket head cap screws in there place?
    Thanks
    indybiker
  2. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    The studs aren't hard to remove,put a rag over the stud and use a pair of pliers to take it out.You'll a need a M6X1.0 bolt in whatever length you need.
  3. 2door
    2door Moderator
    Staff Member
    16,304
    29
    You can also double-nut them. Run a nut down a little ways then another after it. Tighten the nuts together and back the stud out with a wrench or socket. If you use a wrench put it on the nut closest to the engine to turn the stud out. They're usually not that tight unless someone has used red Loctite...then you'll have some problems.
  4. Humsuckler
    Humsuckler New Member
    Jul 28, 2009
    458
    ^ bingo.
    double nuts works everytime. ;)
    if you have trouble finding metric cap screws to replace them, you can always use 1/4" stuff instead. just oil them up and drive them home with a cordless impact driver. once they are in, they are in right?
    (you could use a tap if you have the time.... lol)
  5. nogig
    nogig New Member
    Mar 18, 2010
    122
    I have some cap screws and spacers left from a sbp mount if you need em pm me ur address and ill mail em out monndaydance1
  6. rockhopper
    rockhopper New Member
    Mar 20, 2010
    221
    This thread is not how I imagined it would be. Oh well.
