What the title says , my motor stops at a complete stops witch isn't very good if you you are crossing a busy intersection.
Thanks.
Thanks.
Yes that's it, now try to keep it running with the throttle push in the clutch engage the pin so the clutch stays disengaged then turn the screw with the spring untill it runs by it's self. if that does not work maybe it your gas oil mix.Well the screw is very tight. The gold one on the carb with a spring. Witch if i'm not correct is the idle screw.
