ok ive had this question for a while now and figured i would ask the experts since you would know. I want to build a custom frame bike with the morini 9.4 hp i guess its the S6S model? but i have a question or two before i decide to commit 500+ bucks to this as that kind of money would buy one heck of a sleep number bed instead......i guess firstly, does this motor have to be pedal started....and what i mean by that is if i idle the motor at a stop light, do i have to pedal to build up momentum before i kick back over to motor power or will this thing have the power to kick off from a dead stop? secondly, does the clutch work similar to the china girls in that it has that little swing arm attached to the cable  that disengages the clutch when the handle is pulled in? i guess thirdly, what size rear sprocket should i get for this puppy? is there any kind of special mounting technique or can i use the same kind of rag joint/bolt on that I use with the china girl, will i definitely need to be using the super industrial rims/wheels so that i dont overtorque and destroy my regular wheels?..........man i really want one of these things......
