modified cdi and cr 80 coil
Cavi Mike, its the 9th post back from the end of the thread. It is difficult 4 me, I'm totaly computer illiterate & post from phone. I lost phone the other day & had a hard time configuring new 1, then didnt know how 2 enable cookies so couldnt log on 2 answer u, sorry mate. When I went 2 school I dont think the school even had a computer, let alone students. Cheers
You're talking about this post and this image?
http://motorbicycling.com/showpost.php?p=298658&postcount=32
Excuse me Cavi Mike, this is interesting; is this some type of amplifier to boost the input to the coil? Looks really cool. I just ordered a DC fired race CDI for scooters and such to run my 66cc unti. I will run a small 12volt battery in a rear compartment to power the ignition. Are you guys essentially building your own CDI ?
Thanks
Yes, its a CDI, the 1 shown in that pic is not the CDI this thread was created for, go back thru this thread (page 17, 6th post, by Headtrauma, posting 4 Ivan H) for the schemtic & tips on modifying 2 suit ur own needs, or go to pge 43 of "roll ur own CDI" for schematic (note, the redrawn schemtic has 1 small error in the scr's kathode circuit), pics of both sides of the board & layout. Perhaps someone computer proficient could lift them over 2 this thread. I'm not, I had 2 snail mail headtrauma the origonal hand drawn schematic to get it posted. Cheers
Ok, I thought I'd revive this as it an integral part of getting the power/smoothness I've got from the reed app that I have posted development of in the thread "Reed Kit" in the Hi Performance Tips section. This cdi will run fine as is, a little more advanced than the Jag, the retard kcks in at about same. To bring 2 Jag spec u need 2 reduce 27ohm pull down resistance to 16ohm. Also add a 220 ohm & jumper 2 earth in parellel 2 the 120ohm. Outta phone screen, nother post
In between the Kathode & Gate of the SCR u need a 1k ohm & 390 ohm in series. The resistor in the R/C timing network is increased from 620 ohm to 760 ohm to keep the retard curve kicking in @ same time. Either 1 off the 2 CDI's will give smoother, more powerful opperation, on any China motor. U will need an external coil, CR80 gives hottest spark. The schematic is on Page 17, 6th post, this thread. Cheers
Keep in mind that posts per page are selectable in the UserCP, so "Page 17, 6th post" doesn't work when the entire topic is only 5 pages long. Maybe you should use the post number in the upper right hand corner as a reference instead. For instance mine is #195.
Ok, the origonal schematic is Post #166, this thread, by Headtrauma, posting for Ivan H, thankyou very much Headtrauma, or it still wouldnt b on here. If u want it to the Jag spec c post #193 & #194, this thread, I have posted those values. Either 1 works fine, or u can try changing values, the circuit is pretty forgiving, within reason. Cheers
Hi, this is my first post, so hello all, nice forum lots of great info.
I've been following this thread and have been designing a PCB with ExpressPCB, neat program and its free. I've completed the KDX CDI schematic and my first shot at a PCB. But I'm no expert just a hobbyist who acquired a bike with a dead CDI, After seeing some of the schematics offered by rohmell, I'd now like to incorporate a resister pot to be able to fine tune along with a possibly external thermistor to monitor engine temp and adjust timing and have jumpers or switches to activate these extra features.
I have attached my work in a a ZIP file.
Here is what I have so far....
Ok, so u've got jumper selectable 16 & 27 ohm pulldown resistance with the A jumpers in parralell. I ran my first 1 with 27 pulldown & 1k+100 ohm in series between gate & kathode. My second built (jag spec) uses 16 ohm pulldown & 1k+390 ohm in series between gate & kathode. To have selectable pulldown u also want selectable 100 ohm or 390 ohm to keep the timing of right. Good job. Cheers
the easiest way would b 2 have 1k, 100 & 390 in series with jumpers bridging both the 100 & 390. Then u could select 27 pulldown, leave the 100 unbridged & bridge the 390, or select the 16 pulldown, bridge the 100 & leave the 390 unbridged. Both would need the ability to be bridged but u'd only need 1 jumper as 1 would always b bridged & 1 not. I like how u've made the pulldown selectable, I hadnt thought of. Well done. Cheers
Yeah, ur all good, just do like I said with the 1k, 390 ohm & 100 ohm with jumpers in paralell with thr 390 & 100 ohm. Im gunna do 1 like coz u've made it so u can advance the timing where with just the 2 A jumpers in paralell with the pulldown it only retards so u've made a lot more combinations possible. The charge caps r X2 type 275VAC polypropylene. The timing caps r 35V Tantalum. Note they r polarized, marked +, which must go to earth. Cheers
Ok here it is with all the jumper and up dated parts...
Yep, lookin good. I just do them on pre drilled prototype board with the copper foil strips running vertically, it all lines up pretty well, then I just dremel off the un needed tracks. Well done. Cheers
Now that Dracothered has sorted so timing can b advanced we need 2 know its not 2 far advanced. Ur plug is a good indicator. The sides of the center electrode should have an all over even covering of tan oxide. If the very end 1/2 mm or so shows a band of bare metal the timing is a bit 2 far advanced & the heat generated from this has burnt the oxide off. Advancing the timing can make good power but u dont wanna hole a piston. If u've ever got the motor apart, look at the underside of the piston crown. If its black from burnt oil ur running 2 hot. Cheers
I'm not 100% sure which jumpers do what, so if you could clear that up I will up date the drawing so everyone knows what ones do what.
ok, test 2 set overall timing under low RPM load (acceleration). The most advanced would b to select the 27ohm pulldown, no other jumpers tho it may b 2 far advanced. U could bridge the 100 ohm 4 next most advanced but bridging the 390/100 unbridged is the most advanced I've used. Add either the 120 ohm or 220 ohm will retard it by about 3 or 6 degrees. Outta phone screen, nother post
Now we get 2 Jag spec. Select 16 ohm pulldown. 4 a bit more advance leave the 100 & 390 unbridged, tho 100 bridged/390 unbridged is stock Jag spec. Again, add either 120 or 220 ohm will retard roughly 3 or 6 degrees. If u add both it will retard a bit more. I imagine that between all settings there will b some overlap. 1 more post. Cheers
Ok wotever setting gives best low RPM performance is the right 1. Both 0.47uf caps could b on jumpers if u want tho 1 is good enough. Adding steepens the Hi RPM retard curve. Test 4 position @ WOT windout 4 best speed. Start without jumpers then add 1 @ a time if u use 2 jumpers. Highest speed setting is the right 1, button it up. Thanks heaps Dracothered, u've been invalueable. Cheers
Hi, the way I said 2 add the 120 & 220 ohm jumpers is back 2 front. Add the 220 will retard a little, the 120 about twice as much, the both 4 twice as much again. 4 people in Oz wanting 2 build, components r instore or online thru JAYCAR. Polypropylene charge caps r catalogue No. RG-5240, $2-50 each. Timing caps r catalogue No. RZ-6640, $0-65 for the 4.7uf & RZ-6626, $0-60 for the 0.47uf. The 1/2 watt 1% metal film resistors r there for a few cents each,, as is the prototype board @ about 4 bucks. Cheers
