Misfit Board Tracker
Ralph hop
255
734
93
With the Schwinn project on hold maybe until next winter. I've decided to use the 212cc engine on another bike because I'd like to have a less bulky two stroke dirtbike engine on the Schwinn. Picked an eBay fat tire frame but won't be using wide tires. It's called "misfit" for now because nothing fits on it. Got some free time and some parts gathered and haven't started on it yet except for the headset cups so I'll start this thread with a bare frame and tank. Frame is all tig welded and looks to be the same quality and producer of the cnol truss forks.
Ralph hop
255
734
93
Not much progress has been made except for fitting. Some good news and some less fortunate. Good news is the 110 mm wide bottom bracket will give me free pedal clearance with the 212 motor back to the AV89 motobecane hub. But the "bad news" = some finess on my part. Belt sanding the motor mounts at an angle and cutting excess material from a sloppily stamped clutch drum.
Ralph hop
255
734
93
Rear spacing is 165mm. Rear hub has 200mm X 12 mm axle. Hoping to run a belt straight back but I still have the option to run chain with gears.
  • Like
Reactions: indian22
Tony01
1,840
1,947
sf bay area
With that clutch and its 3.2” pulley if you run a sheave as big as your rim you will be geared approx 6.5:1 on a 26” which is on the tall side but doable with a 212 built for low end.
Belt primary with chain rear works great. Remember to keep the bushing oiled. A drop of motor oil after ever ride.
Ralph hop
255
734
93
The middle inside diameter of the clutch pulley is 2.5 in. and plan to use a whizzer sheave which I think measures 20 in. Rear wheel will be 26in.
MEASURE TWICE
2,771
1,269
CA
I tried 8:1 ratio with 26inch drive wheel connected in the math, if you know what I mean, and it was burning up the clutch with 3hp Briggs 4 stroke and bike weighing 75lb and me 135lb. I had 20:1 and it was good. Faster with 12:1 but hills cannot do nearly as well. The cogged belts, not synchronous drive like timing belt, helps go around smaller diameter pulley without as much heating and wear. I have not seen a manufacturer that makes a sheave pulley that attaches to spokes as large as 26" wheel, but DIY'ers have made their own of that type. With a twin jack shaft set up mixture of belts and chain, I once rode test ride only with 8:1 engine going 2500 rpm and it was really slow less than 10mph. Bronze Bushing oiled with regular 30 wight motor oil is good. Every now and then I take apart and clean bushing, pads, and drum.
Ralph hop
255
734
93
Thanks mt for sharing your first hand experience, I'll have to run a jackshaft. Sheave just came to the door and I doubt I'll have enough luck for a belt to line up straight with my universal style mount anyway. I do have a 44 tooth sprocket. 48t was sold out.
Ralph hop
255
734
93
I'll say it was hard not to choose a sportsman frame. I thought hard about it. Pat has a nice looking tank and the specs I want, also sturdy frame construction. When I went over the options of my engine mount system and also wanting to try something different, chose this frame. To me this product and sportsman flyer's product are apples and oranges difference. I would like to find out if I can purchase a frame and engine mounting system only in the future. The website doesn't share much detail about sales options.
indian22
4,734
7,740
Oklahoma
Ralph when you need something special, it typically doesn't exist on a website; the demand typically isn't enough to justify the mention of it. I often have to ask what's available or what can be produced as a custom order. I do that with wheels and hubs a lot and don't like personally lacing anymore. A few years ago custom fabrication was the only option, really expensive unless you built it yourself. Now a lot more cool stuff exists and is basically ready to ship. Quality varies yet a decent fabricator can deal with some variances. Misfits etc. are pretty common yet with some patience and skill many of these can be worked around... over time.
Price is a factor as is availability, quality and dependability of both product and vendor. I'm also a fan of Sportsman products for several reasons. He's a bike guy and has extensive fabrication skills and experience coupled with being an actual engineer. Fit & finish are really outstanding. He's also one of the early forum members and we're lucky to have several of these guys still posting and sharing with us.
I personally had not seen a 165mm loop frame offered by anyone, but think it a good idea as the Fat tire bikes are quite hot at the moment. I like the look of a wider rear tire and the softer ride as well. I think you've started a great project and am looking forward to following it's progress.
Rick C.
