Nice flow to the lines, engine, crank, pipe is perfectly set. My old eyes think the rear wheel "looks" a tad larger. I'd spend some time doing a walkaround on a bike like that.
Great Job! I like it a lot.
Thanks . I just take a picture of my bike , then i mess with it in MS paint .
A dirt track speedway bike was the look i was going for .. ever seen them race on ice ?
studded tires n all . Forget the fast and the furious .. Drift was invented on these things .The more i look at it ,the more i wanna build it .
Anyways . here is another I drew up a while back .
You know Diceman those frames aren't an impossible build. Don't see many (any?) in those style. You should try to talk to someone about designing such a bike. **** I even have a fork you could use...
Good ideas Ludwig . Keep tryin .. you,ll get the pics up eventually .
Mitch .. the place i live right now is so old , the ( fuses ) blow if you run the coffee maker and the toaster at the same time ... welder ? ya right .
This is a cut and paste job for how the Device is going to be made. The minimoto engine will be held down to 1/2 revs to pass the 1kw test, so it should last well enough.
