My pipe took much more work to fit, but my motor sits low and is tight to the front tube. I had to cut the main chamber in half at the old weld and rotate a few degrees. I had to cut the stinger off and reposition a few degrees as well.  But the bulk of the work was at the pipe inlet, I actually had to shorten the tube about three inches, and then cut and rotate in two locations. Finally, I had to build a new flange from raw tubing, and to get the right diameter it was off to online metals for the tube and to McMasterCarr for washers with the correct OD.  The ID I had to open up about an 1/8" or so. I did all the pipe fitting, and Pat tig welded it back together.  Nothing like a three dimensional puzzle to challenge the brain!
It was quite a bit of work for a proper fit, but in the end, I now have what should be a killer pipe. And the bummer is, I haven't even tried it yet! I fitted the pipe and added some final touches to my frame then tore it all down and off to the powder coater it went. It'll be a solid week before I even get to sample the fruits of my labor.
My previous pipe was a sick bike parts chamber with a small diameter inlet pipe. I am hoping to get some of what Camlifter says I should expect with a real pipe. The bike was respectable before, but I was not getting the full 9.4 HP from it. I expect the new pipe should wake up the motor in a big way.
