Manic Mechanic Hub Adaptor
Discussion in 'Motorized Cruiser Bicycles' started by moronic_kaos, Jun 11, 2010.
  1. moronic_kaos
    moronic_kaos New Member
    Apr 6, 2010
    225
    Got a few questions on this.
    1. Which one fits a Cranbrook (I'm guessing the CB-110?)
    2. How do they mount up? Do they clamp solidly on the hub somehow or do they just sit on the spokes?
    3. Do I have to re-spoke the wheel to fit it inside? (wouldn't bother me, but would like to know)
    4. Are they self-truing? Nothing to center, just bolt on?
    5. If the wheel isn't 100% true (I do mine on a vice & use a marked 2x4 stood on end to eyeball it), will that affect the sprocket being true to the hub?
    6. What happens if I get chain-to-tire rub? Is there a way to adjust it?
    Thanks. Just getting sick of the rag-joint thing having to be redone 3 or 4 times every time I pull it off, and braking like 3 bolts every time I do it.
    #1 moronic_kaos, Jun 11, 2010
  2. bairdco
    Aug 18, 2009
    6,352
    28
    1. if it's a shimano cb-110 hub, then , yes.
    2. clamps to the hub with two allen bolts.
    3. no
    4.yes, as long as you tighten the bolts equally.
    5.no. but an un-true wheel will affect the way your bike rides in general.
    6. the adapter has some lateral movement, you can move it closer to the hub flange to extend it past your tire on most bikes, and also to get the motor cog and the rear sprocket in alignment so your chain stays on.
    7. yes, it's totally worth it.
  3. broHSI
    broHSI New Member
    Jul 27, 2009
    89
  4. CoastalCruiser
    CoastalCruiser New Member
    Apr 28, 2010
    338
  5. moronic_kaos
    Apr 6, 2010
    225
    So how do you tell if it's a shimano CB 110 or equivalent? There's no markings on the thing.\
    Anyone got some sort of measurement?
    Thanks
    EDIT:
    Found that in the description. Says basically the same thing in the title, and the markings indicate inches. What are they referring to?
    #5 moronic_kaos, Jun 11, 2010
  6. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    Check this thread http://motorbicycling.com/f3/creative-engining-manic-mechanic-jim-please-9945-2.html
    Jim used to have the Cranbrook adapter listed separately on his site. You may want to get ahold of pirate and see if they are still available.
    Even though my hub isn't a Shimano that's what I ordered because my hub diameter came in at 1.526"
  7. bairdco
    Aug 18, 2009
    6,352
    28
    to be precise, you need a micrometer to measure your hub, but like kevlarr said, call pirate, tell 'em you have a cranbrook.
    btw, a shimano hub says "shimano" on the brake arm. most other hubs do, also. some have it stamped right into the hub shell. if yours has no name at all, i dunno what kind it is, but whoever makes it must not be too proud of it if they don't want their name on it...
  8. moronic_kaos
    Apr 6, 2010
    225
    It seems to measure about 1.506 (measured with micrometer). Hmm... that sucks. Don't know how the thing looks mechanically (the pics aren't all that detailed), but I'm thinking about getting it anyway and wrapping the hub in some thin rubber to space it out.
    The rubber might bump it a bit (hundredth of an inch or so) in either direction, but that's still a heck of a lot better than the rag joint which is near impossible to align with that little of an error.
    I'm picturing like a 2-piece thing that clamps down with bolts on either side, similar to the way the tensioner mounts to the chainstay, except its more cut from a metal block rather than bent sheet metal. Don't know if that's what it is or not. Hard to tell from the pics.
    EDIT: But that's all if pirate doesn't have the cranbrook model. Will definitely ask when I get the $$.
    #8 moronic_kaos, Jun 12, 2010
  9. worksmanFL
    worksmanFL New Member
    May 25, 2010
    579
    Hi,
    I spoke to PIRATE, and they dont have the huffy cranbrook hub adapter anymore.
    (i own a cranbrook too)
    Our hub is a Shamino Falcon (from me seeing that on the brake arm), and they stopped making the adapter. Supposedly some hubs/wheels have failed.
    you are going to need to switch over to shamino cb 110 or cb 110e hub and use pirates adapter that fits, then see if you can relace your spokes. (or buy new wheel set)
    From the gas engine distributor, they say the rag sprocket attachment is good, and a problem if you put it on an old bicycle.
    I'm gonna give it a shot that way for now.
    Good Luck :)
    #9 worksmanFL, Jun 12, 2010
  10. GeneFiorot
    GeneFiorot New Member
    Feb 12, 2009
    170
    The rag adapter can never be trusted to remain concentric causing the chain tension to vary. Besides the stress is all on the spokes, not a good idea. Pirate sells a really nice wheel for around 40 bucks with the correct hub which also has much better bearings that helps with another safety concern.
    Stainless Steel rear wheel W/ Coaster Brake 26 Inch
  11. moronic_kaos
    Apr 6, 2010
    225
    Well, is there a difference between the Shimano E-110 and the CB-110 in terms of the outside diameter? Because I'm pretty sure those are the same wheels as these:
    Amazon.com: Wheel Master Rear Bicycle Wheel 26 x 1.75 36H, Steel, Bolt On, Shimano CB, Silver: Sports & Outdoors
    That particular picture doesn't work for some reason, but note that particular store on amazon uses that same picture (on the piratescycles page) to sell all their other wheels. An example:
    Amazon.com: Wheel Master Rear Bicycle Wheel 26 x 1.75 36H, Steel Bolt On, Silver: Sports & Outdoors
    EDIT: Not to mention, the specs are identical
    Just sayin.... (only because pirates is out of stock at the moment)
    #11 moronic_kaos, Jun 12, 2010
  12. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
  13. moronic_kaos
    Apr 6, 2010
    225
    Haha I like it already:
    But there stems my previous question, this one's got the E-110 and the pirate adapter is the CB. Are they the same size? If your hub wasn't shimano then there's really not much way to compare the thing.
    Though I still like the rim either way. LOL to 11G spokes.
  14. worksmanFL
    May 25, 2010
    579
    Hi Gene,
    Thanks for the info. :)
    My tire is 26 x 2.125, 36 spoke if I remember correctly.
    The post is for 26 x 1.75 36h, which is out of stock. I guess i'll call PIRATE monday to see what they have.
  15. GeneFiorot
    Feb 12, 2009
    170
    Good Idea and I think 3/8 increase in width is a plus . I also understand he has wheels that the adapters fit with heavy dia. spokes. can't beat that either.
  16. CoastalCruiser
    Apr 28, 2010
    338
    You could just shim out the hub with lead flashing or thin aluminum and use the available adapter.
  17. GeneFiorot
    Feb 12, 2009
    170
    I guess you could try that but if it slips you will rip up the spokes. You really need an interference fit.
  18. moronic_kaos
    Apr 6, 2010
    225
    Your tire *SHOULD* have enough flexibility to fit on the thing. This is just coming from my experience buying tires at Walmart. On most boxes tires come in, they give a range of rims they'll fit on (for mountain bike/cruiser it usually goes from 1.75 to 2.125)
    But... thinner rim = weaker rim in most cases.
  19. CoastalCruiser
    Apr 28, 2010
    338
    Interference fit? We're not pressing in a sleeve here. 19 thousandths of an ich difference aint much. True it's not an interference fit but, a slice of beer can would make up the difference.
    #19 CoastalCruiser, Jun 13, 2010
  20. GeneFiorot
    Feb 12, 2009
    170
    Maybe I have used the wrong term but another component could be a source of slipping and that would not be good. But I do not know. One thing I do know is Jim could have provided lots of desired shims instead of making all those custom dia. adapters. I figure he had a reason. Also don't you have to shim it out to the exact original dimensions so the bolts line up with the sprocket holes?
    #20 GeneFiorot, Jun 14, 2010
