What Dave is saying, Mike, is that fuel/oil in the magneto case is usually an indication that the crankshaft seal behind the rotor(magnet) is defective. That can create some problems in the way the engine runs and performs because a bad seal usually will allow air to enter the crankcase and cause a lean condition much the same as an air leak in the induction circuit would. Eventually the gasoline will attack the insulation surrounding the coil windings. You've been lucky. Keep riding until something goes haywire then you'll see what we're talking about. Me thinks it's just a matter of time.Mine is drenched in gas/oil and has been almost since the day I've got. Never had a problem with it. You do know that oil is used to cool transformers, right? Epoxy isn't affected by oils/petrolates.
so my bike is not getting a spark, replaced the cdi and the carburator neithher worked, cheked the magneto and it has gas/oil on it. i there a thread already dedicated to what to do if this happens? sorry if there is![]()
