Buzzfire,
Are you using the chain tensioner? You should be and that's how you adjust chain tension. The wheel/roller will need to be moved upward to tighten the chain. The kit supplied chains are almost always three or four inches too long for most bikes. You'll need to remove a few links. There are any number of posts on this forum dealing with chain and how to cut them. There are tools made to press out the pins in the rollers or you can grind off the ends of the pins and use a small punch and hammer to drive the pins out. When you install the master link make sure the closed in of the clip is facing forward on the top chain or the portion that is entering the motor. We could offer more help if you could post a photo of your bike and especially a good picture of your chain tensioner installation. Ideally you want about 1/2 to 3/4" play, or slack in the chain when installed. You measure that on the top chain with the bike moved forward until the chain sags. Less than a 1/2" is too tight, more than 3/4" and your chain is loose and can bunch up on the engine sprocket locking your rear wheel. Hope this helps you.
looks like you may have the sprocket on backwards, take it off the wheel and flip it over. that will move the chain out away from the tire more and line everything up better.
So as far as the carb goes. Do I need to move the carb from the engine. I am not seeing a screw underneath that I can unscrew to drain the excess oil.
Buzzfire,That is interesting.I was wondering about that. So the sprocket needs to be curved outward? I thought I did that but I will check it again.
Thanks I will give it another go.![]()
Buzz,Tom thanks for the encouragement. It gets frustrating. I changed the fuel and oil. Mixed brand new oil and fuel. Could I have flooded it? How would I know?
Congratulations Buzzfire,As of today I got it running. I took around the block a few times. As suggested I replaced the plug, and discovered one of my wires came lose. After that it fired right up. I checked all the bolts and nuts. It sounds a little choppy. It has lots of power but sounds loud and choppy.
