MoreBloodWine
Stupid question but on the note of the gas line, how close can it be to the head before one should be concerned ? I know you said it shouldn't be touching but there still has to be a ditance thing right ?
Also, pre-heated fuel is not good and under extreme circumstances can cause vapor lock.
If you give the line a bit of a twist it will bend for you. You should be able to make it bend out of the way of the head.
The carb should be okay there. It's not perfect, but it's as good as you're likely to get. There might be a better combination of carb/intake out there. Mine has about the same tilt. I'm still new to the motorized bike game, so I don't know exactly what's available out there yet.
The fuel line looks good too. You could even zip tie it to the frame tube for insurance.
Looks good to me! A little tip about rubber hoses. Sometimes it's a pain to get them started over the fitting. A little spit will let it slide right on.
Sorry.
Grab the hose with a pair of pliers over top of the fitting to which it is stuck. Rotate back and forth while pulling it off. If you can get it to rotate, you can get it to slide off. If it's really stuck, use a blade to cut the rubber. I'm glad they go on easier than they come off.![]()
