here's what I have done to my predator build. I will be running some kind of jackshaft. I will probably use the shaft from AGK. I'm getting kind of deterred away from the build. It's my first non kit build and I feel like it will not work out well or properly. Maybe because it's my first time. I will probably keep the exhaust as is...as it doesn't interfere with pedaling. I've run the engine on the bike and revved it a few times, doesn't seem to vibrate AT ALL, and seems very solid. I will be using a happy time gas tank as well as the throttle grips too. Probably switch carbs too. I still need a gas tank, fuel line and filter, different carburetor, jackshaft, 56t rear sprocket with hardware, throttle grips/cable, bottom bracket conversion kit and pedals to go with. I think that's all I have left...I have a really good feeling about this project...but at the same time, like something won't work. It would be a lot easier if I had access to welding equipment and someone to use them.(I personally can't weld) If anyone would like to PM me and keep an eye on my progress that would help alot! Here's what I've got so far.
