Hyper Cruiser Question
zean
316
200
43
california
Say, does anyone know if it is safe to spread the width of the rear drop-outs on the Hyper Cruiser, the steel frame, from 110mm to 135mm to replace the single speed coaster brake rear wheel with a 7 speed free wheel? I will use the bicycle for two to three thousand miles at speeds no greater than 30 mph. Thank you all for sharing your experiences,
  • Like
Reactions: indian22
Tony01
1,610
1,379
sf bay area
It’s fine. Make sure everything is straight or you’ll have issues with the axle tightening and possible bearing cup issues if loose ball type.
  • Like
Reactions: indian22
BrandFord2140
9
27
Same kind of idea except I used a screw Jack and it worked perfectly still can have to barely pull the frame over the night but I don't mind doing that and it is straight and true still
  • Like
Reactions: indian22
