Update time for the Cranny, picked up some new goodies for my birthday. Installed a Jaguar CDI, Puch 70cc hi hi head, made a plexiglass cover for the CDI, Skipu spring loaded chain tensioner, and have a Sturmey-Archer 90mm XL-FD front drum brake on the way.
Here is a pic of the Jaguar CDI installed:
Definitely need to cover that up... lol. I used some plexiglass sheet and a heat gun to make a cover. I am not completely happy with the way the cover turned out, but good enough for now
Unfortunately I need a half link to take up the extra slack to use the spring chain tensioner, so for now still running the old one too, lol.
Looking at the pictures, I REALLY need to shorten that throttle cable!
I went with the 70cc Puch head and two head gaskets instead of the 50 since I wanted a little more power and cooling, but did not want to make the bike too difficult to start. It feels like the 70cc head does just that. Starting feels about the same as stock and the clutch does not slip, and the increase in torque is very noticeable.
The Jaguar CDI added some more grunt, so the bike gets up to 30 MUCH quicker than before. I still need to play with the timing jumpers, but so far I am really enjoying the head/CDI combo. The little China Girl does not feel nearly as anemic as she did stock.
Now the bad news, the pinging noise that I was hoping was related to heat or the stock CDI looks like it might actually be my wrist pin bearing. I hit 38 MPH today, but there was a LOT more of the spoon-in-a-garbage-disposal sound. What I am hearing sounds exactly like the sound from post #1 in this thread:
Weird clanking noise during rides From the feel of the motor, I think she could hit 40+ if I can fix the issue causing the noise, since it is accompanied by a loss of power.
So, looks like I will have to finally pull the cylinder off and replace the needle bearing. Hopefully I will not need to replace the piston too, but the guy who made that post cured the problem by replacing both since it seemed like it was piston slap in his case. I will also trim the piston skirt while I have the jug off too, so it opens up the intake port. Wheeee!
