How does the CDI know when to fire spark?
arguevera
11
27
This is more of an engineering question, but I am curious, given that the CDI only takes in two wires (for what I assume is positive and neutral), how does it know when the piston is located to fire a spark?
2door
Moderator
Staff member
16,337
166
Littleton, Colorado
Wheelbender is correct. There is a magnetic signal provided to the CDI generated from a rotor, or rotating magnet on the crankshaft. The magnet, or rotor is indexed to the crankshaft which determines piston position.
ivan H
622
australia
Ok, a 2 wire CDI works like this. The magneto produces an AC voltage. The positive going (upper) half of the waveform charges the CDI's charge storing capacitor. As the waveform goes negative (lower half of the wave), it triggers the CDI to fire. It is very early in the negative going half of the wave (like a few volts negative potential) that this happens. There's a bit happening to make the spark at your plug, but that is the gist of how its "timed". Hope this helps. Cheers
Edit; I know this thread was dormant for a couple of months, but seeing as it hadn't been answered how a "two wire" CDI, where there is no crank sensor or firing coil is made to fire I thought I'd explain it, in very basic terms, without going into the electronics of the CDI. Cheers
  • Like
Reactions: junglepig
Russell
1,273
144
MA
Thank you for clearing this up in basic understandable terms. Also thanks to others that helped also.
