Honda GC160
cantona7
Hello all,
I've recently got a hold of a Honda GC160 engine off of a pressure washer and it runs great. Looking to use this on a build.
However, I do have an issue with the flywheel fins. I am working towards a stripped down clean look and the gc160 I have has the cooling fins as part of the flywheel. I saw builds here that use this engine and they all have the plastic removable cooling fins, which makes life a lot easier of course.
So, I was hoping to see if those who used the gc160 with plastic fins could share the model number of their particular engine.
I'm thinking maybe i can just find a flywheel as a replacement part somewhere and use that. Or just get a new engine with the plastic fins.
Thanks.
You may be able to get an aftermarket flywheel, I'm not sure if they are made for the gc's or if a gx flywheel would fit. Also, if your flywheel is aluminum and not cast iron you may be able to grind down the fins. Look up cobrafreaks build, he used a billet flywheel but ground off the fins for a nice clean look.
I know the GC series and it may be best to just purchase a new motor. We just blew one up a d I should of saved a few parts... Would have sent you the flywheel just to help out.
Let me know if you have any questions.... Ccc
I tried, there is not a whole lot of aftermarket parts available for the GC160 unfortunately. I would love to upgrade to a alum flywheel, but all the stuff that's available is for GX models.
Well, if you have the flywheel in one piece, I would love to take that off of your hands.
I checked with them, gave them a call and spoke a little about the GC160, they weren't sure whether the flywheels they have would fit the GC engines, they are all made for the GX models.
I would call them up to see if that would work. There is a difference between a GX and a GC series.
Yes, there is a difference as I am finding out. Might just have to get a new engine. Or buy your flywheel :)
Thanks everyone for their input. I will report back, once I figure out what I am doing (for future reference to other readers).
How about start the engine and set it at a faster ideal and hit it with a grinder untill the fins are gone or smoth. I have seen it done and a lot cheeper then one you can buy........................Curt
I would try what Curt mentioned.
I am sorry to say I threw the motor away about 2 weeks ago, wish I would have saved the flywheel.
That is a great idea, makes me a little nervous but I'll give it a shot.
Oh, too bad u got rid of it, should have posted something earlier lol, I'll try Curt's advice and give that a shot.
Thanks guys
If you take the time to grind the fins down pretty tight it might not cost too much to have a machine shop face it off...? Or better yet do you have a friend with a lathe?
It may also be possible to first break the fins off with a hammer to save you some grinding time( ?) Although I can’t say that for sure as I’m not that familiar with Honda GC’s.
Good luck & don't forget to post photo's! :-)
-Kirk
I took the Hammer approach to the fins. It worked great for me because my flywheel is aluminum. I do not know if it would work so well on the metal version of the flywheel.Some gc160 fly wheels are aluminum and some are metal.
