Hello. I would appreciate some different opinions on the maximum rpm a stock Honda GC160 can run at with only the governor removed, and is the governor removal similar to removing the governor on a GX series engine? Can the piston hit the valves when the valves float on the GC engines? I've read that valve float on the GX series is a safety measure. I like the look and weight of the GC160, I'd like to run it at a 9 or 10:1 reduction ratio at 5000 or 5500 rpms with only the govenor removed to get 37-40 mph while being reliable. Thank you for any responses. I appreciate it.
