hi, newb here trying to learn
bobby
101
ny
great info again. im going to run 26x2.35 front and back. maybe 26x2.5 idk yet. but i am going to run a rear drum also. so i would have to buy a chain tension kit? or could i mount the sprocket outside the frame?
Masterm222
132
Billings, Montana
I have always thought the stock chain tensioners in the kits are junk. Have you seen the new spring loaded chain tensioner at Pirate Cycles? Kipspringer? In after market parts. Thing is, whatever tensioner you use you still have to keep chain aligment correct!
bobby
101
ny
140$ is out of my range. so how will a chain tensioner help keep chain off tire? could i use a slide made of plastic? as a spacer and a guide?
bobby
101
ny
i was worried aout the crank and original pedals. i think 26"x2.5" will rub stock chain. is their a kit that pushes the rear hub out to clear bigger tires?
