introducing the bairdco prototype cruiser.
the main reason i used the rag joint is i wanted to build up the bike as the "introductory" model. using most of the kit parts, i was gonna price this at $1000. then the price would increase with the upgrades.
now it looks like this is the "never gonna build another one and i can't wait to get it out of my sight so it doesn't remind me that i got screwed" model.
another note on the rag joint, it is functional, just a pain. the way i did this one to (mostly) clear the Fat Franks, is i put the sprocket dished side out, then 2 half moon plates, then the rubber, spokes, rubber, half moons.
having the extra plates behind the sprocket gives you a little bit more clearance.
silverbear, it was a full size fender. i just laid the front fender inside to trace the same end-cut, then tin-snipped it off.
i found that trying to notch a fender and keep it long on one side never seems to work.
i never used one long enough to notice. if they were tightened properly, i wouldn't think so, since there would always be even pressure on them as they rotate.
