Help ?????
aust
wont start ?? good blue spark, black to black , blue to blue , white blanked off and coverd, plug wet after trying to start tryed some easy start spray no go ,:-||
Plug shouldn't get wet. Remove plug clean and dry (throttle body cleaner works wonders), then install. Choke is on in the up position (I never have to choke mine). Cut off fuel, drain bowl and give it a shot.
I just sold a boat that had sat in my back yard for YEARS. Sprayed either in a bad carburetor and it started on the very first pull. How's the compression?
Alf is spot on!
That's why we love 2 strokes...
All they require is compression, fuel, and spark to set it off.
One of the three is not in proper order.
Good luck
rc
