cannonball2
The $60 was on auction, the seller had three of them in that format. I lost the first two. Normally he sells them for $75.
We will see how it goes. Have been running the Flying Horse doing clutch research and don't want to remove that engine just yet. Both this engine and the Box engine are waiting to be run. Incidentally the Box engine is the same engine.
Looking like for the actual new engines hitting the shores(and not sitting off shore waiting to dock) Daxes type and this one are the most common. These(FM80) are easily identified by looking down the plug hole and checking the piston top. If It has a triangular arrow its the FM80 engine, at least the three I have seen are. The engine you have I believe is the ZAF80. These two are GT5 types identified so far as far as I can determine. I would call them 114mm rod engines. The rest as far as I know are 110mm rod.
The real odd ball is the ZAE50 crank I believe its the only one that will make a half breed.
I bet the other engines out there being sold are either NOS older 40mm or half breeds. But once again who knows!
