GT2-A frame
Discussion in 'Motorized Bicycle General Discussion' started by nastygramus, Nov 29, 2011.
  1. nastygramus
    nastygramus New Member
    Feb 25, 2011
    99
  2. nastygramus
    Feb 25, 2011
    99
    Ok just checking in with a stupid scratch that an uneducated question looking to put a monark springer front end on this build but with the 1 1/8th inch fork tube do they make one for the larger size fork tube or spacers to make up the difference ?
  3. Flight Risk
    Flight Risk Member
    Jan 25, 2010
    71
  4. nastygramus
    Feb 25, 2011
    99
    WOW another painful finding went to mock up rear tire and NO way will the one off my curzer fit!
    Can anybody point me into the right direction for a rim that will ?
    The rim off a mountain bike does ? but want to stay with coaster brake rim (bought the adapter) for hub drive chain
    Sure glad I started early on this project might be a long PAINFULL $$$$ build good thing is it will be OBMF when I get her done
  5. nastygramus
    Feb 25, 2011
    99
  6. azbill
    azbill Active Member
    May 18, 2008
    3,367
    check out the 'abraham' fork by nirve
    looks like a monarch, but heavier duty and made for 1 1/8 ;)
  7. Velodrome
    Velodrome Well-Known Member
    May 27, 2011
    2,266
    44
    Bill Are you thinking bout the Felt Abraham fork ?
  8. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    My brother runs a Felt Abraham fork on his build, it's real solid. And heavy.
  9. culvercityclassic
    culvercityclassic Well-Known Member
    Sep 27, 2009
    3,089
    59
    I run that fork on my new bike and it's solid...and strong
  10. nastygramus
    Feb 25, 2011
    99
    Very nice looks HD not sure if I can get it to work with that long of a Head tube ?
  11. azbill
    May 18, 2008
    3,367
    sorry,,,I WAS thinking the felt, not Nirve ;)
    at least I got the abraham part right LOL
  12. nastygramus
    Feb 25, 2011
    99
    Any help is good help (kinda)when you need it thanks !Ive looked at both still looking for some spec to make sure I can make it work seeing the head tube is not normal size working on finding the right parts ONE PIECE AT A TIME I GUESS aint going to be a cheep build but if everything goes right should be OBMFMB Thanks for the help !
  13. SAVED1
    SAVED1 New Member
    May 29, 2011
    70
    looking forward to seeing the pics of the build and to hear how the build is working out for you :)
  14. chainmaker
    chainmaker New Member
    Jan 19, 2010
    2,597
    Why wont your cruiser rims fit? You could always re-lace a MTB rim with a coaster brake hub. I have done that..I actually have a set of Alex dbl wall mtb rims with a Shimano coaster hub and stainless spokes I built last spring I was going to list in swap-n-shop.
  15. nastygramus
    Feb 25, 2011
    99
    The hub for the cruzer rim is to narrow/short with the nuts all the way out you put it on one side and the other just touches the inside ? looking into a HD rim set up waiting for a response from the vendor
  16. chainmaker
    Jan 19, 2010
    2,597
    I saw those frames are available with 110 or 135 mm spacing on the drop-outs...sounds like you got the 135mm for multi speed hub.
  17. nastygramus
    Feb 25, 2011
    99
    looks like it there was no option to choose when I ordered it :( what are my options
  18. chainmaker
    Jan 19, 2010
    2,597
    If it was a steel frame you could probabally coherse the dropouts together but I guess aluminum doesnt respond well to bending. Either a hub swap ( Im pretty sure the shimano nexxus hub is 135mm and some guys are making hub adapters for those) and you can get them with a coaster brake. That means new spokes, a hub, and adapter. Or you can order an axel for one and rebuild your hub and replace the axel with the longer one. Good luck keep us informed on how it goes.
  19. chainmaker
    Jan 19, 2010
    2,597
    I saw a few longer axels here Hub
  20. nastygramus
    Feb 25, 2011
    99
    #40 nastygramus, Jan 8, 2012
