here is a new video of the stuffed case build
https://www.youtube.com/watch?v=IVnN1kBaxWk
i find videos to be more usefull than pics and its easyer to explain what you need to by vid vs pic....
anyway...
i figured out why the magneto wheels are all over the place ..... they are really not all over the place with the timing, what the differance is from motor to mnotor is the timing differance between the 40mm stroke and the 38mm stroke motors and there various con rod combos and piston wrist pin hights, so if you have a 38mm stroke and a ZAF-60 rod with the high pin , the magneto wll be keyed differant than the 38mm stroke with the ZAF 50 rod and low pin ... it acounts for the differance in port timeing via piston pin hight... also the 40mm stroke will be differant than the 38mm stroke and so on and so on .... this acounts for all the differant magneto timing changes from motor to motor.
thought i would post that because i saw quite a lot of people ask why the mag wheels were so differant even through out the same size 66cc motors and the 40cc motors, and from what i have learned its because of all the differant stroke, wrist pin, and con rod combos....
i am willing to bet that if you had 2 mag wheels from 2 motors that are the same stroke with the same rods and piston pin hights they would be right on with each other to within the normal tolerances for this type of motor
enjoy the video !
for the coils themselves.. well they should all be the same between all the 66cc and 70cc motors and all one has to do is choose the one with the best continuity and soldered joints
ohh and i plan to add a secondary coil behind the main so i can have a dedicated coild for lighting and not have to draw energyy from my main coil and spark !
