Golden Motor electric owner from Tucson, AZ
peterarev
My name is Peter Anton. I bought a 2008 500Watt electric Golden Motor with a 2009 controller and 36Volt 12Amp-Hour battery pack at the end of 2009. Since then I've ridden it 2500 miles since my bicycle is my primary transportation. I did the installation myself onto the front fork my 1998 Schwinn reproduction of a 1956 Cruiser with a 7-speed internal rear hub.
The motor itself seems durable enough, but I'm already on my third battery pack due to internal failure of either the individual cells or the battery management system (BMS). Everything is covered by a 1-year warranty so that's cool, but I'm a bit concerned about ongoing battery life after 1 year. So far, I've gotten replacements and I'm rather expecting a new 1-year warranty on each replacement, but it's too early to tell if that's the case in the long run. Other than that, I'm quite satisfied and thrilled to be roaring around comfortably on a heavy bike sometimes loaded with groceries and other heavy items.
With a new/healthy battery can travel about 20 miles on a single charge if I pedal along and use the throttle conservatively. I also sometimes carry my charger along with me if I'm going to be somewhere for a while to extend my range. My average usage is about 10 miles a day but a 15 mile run is not unusual. I now have a 2nd battery pack and I plan on building a piggy back arrangement to carry both packs if I want to take a particularly long trip. But then I'm getting into concerns about a flat tire so far from home. Mostly I got the other battery so I'd have one if the other needs servicing or replacement. In the future, I hope to learn how to repair them myself but will have to wait for some kind of little seminar with the dealer. I'm just a die-hard do it yourselfer.
See the attached photo of the bike. I'm not sure how the attachment system works so I hope it camecvlt1 through.
Here's to hybrid pedal/electric biking!
Peter
Welcome to the forum,. Petearev. I have an older version of the same Golden Motor, same 36V controller. At the time I have it sitting on a shelf as I am so busy with gas motor bikes, but a day will come when it will be powering a bike again. At the time I shelved it I had it powering a 1934 Elgin step through and became disillusioned with the weight of the lead acid batteries on the rear rack... very heavy and it made the bike feel unstable. If I were to use it again on another bike I think I would set it up so the batteries were located off the bike in a kiddie trailer. I've also considered using it as the pusher wheel on a sidecar, keeping all the weight of the wheel and batteries off of the bike. I don't have the kind of money it takes for the light weight newer generation batteries.
Lots of good folks here to share with.
SB
Thanks for the welcome, SB,
I forgot to mention that I have a lithium-ion battery pack that only weighs about 7 pounds. It's on a rack in the back which balances the similar weight of the motor on the front wheel (although that's unsprung being the hub and all.) I almost bought lead-acid at first for the cost savings, but a problem with the first wheel he gave me caused a delay when I decided to spring for the extra $350 for Li-Ion. Now I just discovered that the replacement pack I got for my original battery is a 16Amp-Hour pack. It's a pound or two heavier than the 12Amp-Hour original, but should offer several more extra miles. It also has a carrying handle and slides onto a rack and locks in place with the ignition switch - very convenient. I don't think I'll ever consider lead-acid again. Years earlier, I also considered installing a gas motor, but my internal gear hub is too big to accept the drive gear. I'm glad that didn't happen either because I LOVE the quiet operation of the hub motor.
So anyway, on to the topic forum to see what's shakin' in the world of motorized bikes.
BTW, I fully agree with your signature line.
Peter Pan
Welcome to the forum. I've been looking at hub motors for some time, but I can't afford the batteries I would need for a 15 - 20 mile round trip to work.
How do you like the front wheel drive versus a rear hub motor? Could you please give a summary of front hub handling characteristics, pluses and minuses, as you perceive them?
Looking forward to your posts.
.flg.
Catfisher,
I know I'm not the one you were asking, but I'll put in my two cents worth anyway. I didn't notice any particular difference. I guess it is comparable to front wheel drive vs rear wheel drive cars. With the hub motor he front end is heavier, but with batteries on the rack the whole bike was heavy. Once moving it was good. With lighter batteries, you'd probably like it fine. At one time I had both the Golden pancake hub motor up front plus a Bikebug gas friction drive motor driving the same wheel. Most of the time I was using gas, but electric alone starting out and both when it came to inclines. It was nice except for the weight of the batteries and the placement of them too high up. Along with two hundred pounds of circus bear on the seat it was one heavy rig going down the road and on a 1934 Elgin it was different all right... ha! I think the concept was fine. With light batteries, the hybrid setup gave a whole lot of range and had the potential for a regenerative setup so the batteries could be recharging while under gas power. The little bikebug motor was just 26cc, adequate for flats, but wimpy on hills. Light batteries open up a lot of possibilities.
SB
I think there is a HUGE difference between front and rear wheel drive. I haven't ridden a rear wheel drive electric bike, but have ridden several sports bikes throughout my life and owned several motorcycles. There's one thing that distinguishes these from a front wheel drive: the weight and "moment" or torque of the power is in the favor of traction as the front wheel rises and more weight transfers to the drive wheel. On a front wheel drive it is just the opposite, the weight tends to transfer off the drive wheel or at least not transfer to it. Although there is no tendency to wheelie, quick starts are virtually impossible as the wheel spins out and traction does not catch up until moderate speed is reached. Even at cruising speed, small bumps in the road will cause the drive wheel to jump and spin and then skid when landing again interrupting power to the road momentarily. In addition, all this causes increased wear on the tire.
On the plus side, there are some convenient and beneficial effects of front wheel drive. When standing still you can turn the wheel as far as it will go and spin the bike around to face a new direction. This ability rapidly diminishes as the gyroscopic stability of the spinning wheel increases with speed, but it can be helpful in many very low speed riding situations. At higher speeds there is a bit of a stabilizing "power steering" effect since the drive wheel always pulls in the direction of power. There is also an advantage in certain surface conditions such as sand or pea gravel. If you still have your pedals and gearing you essentially have a two wheel drive bike, although coordinating the two can be a bit tricky. I have a lever throttle instead of a twist grip so it's mostly just a matter of charging through quickly under power and pedal with the cruise control set. Normally, the front wheel bogs down in a soft or yeilding surface, but with power it climbs out of it providing you have enough momentum and/or rear wheel power. Also, as I've mentioned earlier is that the weight of the installation is split over the front and back. My battery pack is on a rack over the rear wheel. If it were all on the rear, I'd be really stressing my rear spokes and tire and taking even more control weight off the front wheel especially with a full load of cargo in my rear baskets and on top of the battery (I routinely carry a 30-pack of beer home from the store this way in addition to a large bag I always carry and the other basket full of other items.) Finally, the motor acts as a front brake by turning into a generator when the either of the brake levers is applied. I don't even have brake cables attached as my cruiser has a coaster brake and didn't come equipped with front brakes. The "regenerative braking" is very smooth and "reverse progressive". At high speeds the braking force engages the most and as the bike slows it gradually diminishes to nothing. It doesn't cause the dangerous break in front wheel traction on slippery surfaces that a more positive brake does. (The electrical recharge advantage of the brake is minimal and would only come into play if you decended from a VERY long and steep slope. It is virtually impossible to pedal against the brake on a level or even moderate downward grade. It's only intended use is for braking.)
A front wheel installation is far from ideal, but the reason I did it was to preserve my 7-speed internal hub in the rear. Two hubs simply can't occupy the same space. I'm not a performance rider and am simply happy to have electric assist at all. The fact that I can ride even if I don't feel like pedalling significantly makes my bike a very workable primary transport. My truck sits idle the vast majority of the time and it almost seems a sin to pay the yearly insurance bill which is many times more than what I pay for gas even at 8 miles/gallon.
Peter
I wouldn't want to give up a nexus hub either, especially if it had a coaster or roller brake. Maybe a Cyclone kit might work OK with a Nexus hub.
