I fully agree that people also bump up the shipping costs to boost profit, lots of ebay sellers do that over here, and they do tend to take advantage of bumping the shipping up when sending out of the states.
I'm too new to this forum to have seen all of Fred's posts and I really don't know what kind of a person he is, but he does have an excellent product. But also in saying that, it doesn't matter how good your product is if you make arrogant or rude comments to potential buyers. There is 2 types of quality everyone should never forget when selling their stuff... Product quality of course, and Service quality... they both have to be excellent or people will buy elsewhere. I've already seen some Fred head knock offs on ebay and on other sites that are constructed very similar (they look almost exactly the same as his except they did the fins slightly different), and with the Puch head having very close to the same specs, that leaves your service quality that one must rely on.
I bought Fred's head because his was one of the best designs out there and proven by other people's comments in here and in the other forums confirming this. i got his head here and it is built very well and it's huge heat sinks (fins) and thick construction really keep the heat down, even in an un broken in engine with other upgrades added, I have nothing but good to say about it's build quality and performance, but that's no excuse to offend people in the forums and will cause others to look elsewhere. Like I said, I don't know him and I'm not judging him as a person, but if what you say is true, it can and will hurt his business. I'm hoping that was a misunderstanding, but without knowing for myself it's not my place to say buy or don't buy...
The same thing happened to me with a jug I bought from BoyGoesFast on ebay, it came with an intake that I won't be using so when taking the bolts out, one of them twisted right off, it looked like they used some red (super strong) locktite on the bolts when they installed them. The metal was also really soft so when I tried to easy out the broken bolt it wouldn't catch but I got it out by carefully driling all the way thru it. i'll need to re tap the hole and put in a helicoil before I can use it tho. This jug is decent quality but the ports are very sloppy with the plating overhanging the port openings, but the inside of the bore is nice and uniform plating, but also very smooth like almost a polished finish so it will need some mild honing before running as well. I had to cut off .009" or about 1/4mm to true up the deck as well, but no big deal since I cut off 1.25mm from the deck surface to set squish clearance, and may need to cut it some more once I mount it and measure where the piston top is. I got the copper gaskets from Juice Motorsports and they are really nice quality, but shipping was a bit slow, and the base gasket will need some slight trimming at the transfers.
As for the Tillotson carbs, I was able to find specs on most of them by going to their site and clicking on each carb where they tell the port and venturi diameters, but still not finding info on the older carbs they don't make anymore. They do make some awesome looking race carbs for the KT100 engines and other larger 2 and 4 strokes... even a 42mm which would be perfect for my Harley, but they do have lots of cantidates for these engines in sizes from a 16mm venturi up to 24mm and bigger. I don't see the need for anything bigger than 20mm for the venturi size unless someone does some serious mods to accomodate that much carb. Here's a sample of the race carbs from their site...
http://www.tillotson-racing.com/collections/racing-1?page=4 but I'm still looking for a site that talks about the older carb specs to make it easier to match up one off ebay for our engines.
