I would recommend that you also make the following mod on your gas tank. Scrape, sand, etc. a circle about the size of a nickel or quarter around the base of the tank studs. Also do the same with the studs about one half to three quarters inch from the tank towards the end of the studs. Take some jb weld or similar and build up a cone in this area. This will really help prevent a leak at the base of the studs.
One more thing, if you haven't already done it, rinse out your tank with your gas mix to clean out any "factory debris" that may be there. Best to do this after you've done the above mod to eliminate the chance of oil getting on the studs or the base of the studs. This will help get better adhesion for the jb weld.
