it heats up about the same, but there is a performance improvement. all the motors i've reversed are faster than stock.
there's a lot of different theories tossed around as to why it would be faster.
one, the motor spins counter-clockwise, so it's flowing straight through.
two, the ram air effect. i doubt that comes into play at the low speeds these bikes go, and they seem to run leaner with the carb in front, but i think not having the carb stuffed in the rear behind a hot engine helps. it gets some fresh air, so it should breathe better.
three, since the transfer ports in the case are now twice the size, it gets more fuel mixture, and lubricates better.
i clean up all the ports since i have the engine apart, so i'm sure that helps, just like it would if it's not reversed. but it does seem to run faster.
and cosmetically, it looks bad ass...
