Yep done a couple works good. Cut it in the center,find another fork with the same size and cut it to the length you need to add,leaving a 1/8 space for weld. Find a 7/8" od tube to fit inside cross drill a couple rosette weld hole, stick it together. Leave the bottom bearing race on so you don't have trouble fitting it latter,don't have to grind it to much just enough to get the bearing on................Curt
