silverbear
The Boy Who Never Grew Up
I know some of you guys used to be auto mechanics and at least a couple of you worked in the auto parts supply industry. A year ago I bought a pristine 1981 Ford F-100 Ranger from my brother, with about 25,000 miles on it. Sweet. Now it's around 31,000, but still a really nice truck with a 300 cubic inch straight six engine. This summer it started running rough at idle and I took it in to have the problem diagnosed and fixed. Apparently Ford used a mixture solenoid on their carburetors from I believe 1981-1985 or so when they switched over to fuel injection. These mixture solenoids were not the best idea and fairly often needed to be replaced which was not a big deal as they were bolted on to the outside of the carburetor.
It is a big problem now, though, since that part is no longer available... at least not through my local NAPA dealer. And not available for 1981 on ebay either. I have a mechanic trying to track one down, so far without luck. I did see that there are replacement carburetors out there which appear to be Chinese clones of the Carter carb. Don't know if they come with a mixture solenoid or if the carburetor clone is enough different that it doesn't use the solenoid.
The truck runs, but poorly at idle and will sometimes stall out at a stop. By chance does one of you reading this know of a source for this part, or whether a clone would solve the problem or if there is a way to either bypass or repair the solenoid? I'm able to drive it, but would sure like to get it fixed before winter settles in. Any ideas?
SB
SB
