nightcruiser
I just took my first ride, all in all I think it went pretty well, but I definitely need some help to get it right.
I have a Grubee SkyHawk 2010 66cc kit w/ 20:1 gas mix for break in.
I tried to fire the engine by taking some short jaunts and pulling in the clutch, got a few pops but wasn't able to get it going. I got out on the road with some speed and popped the clutch and she sprung to life and seemed to run pretty good for her first gasps! I immediately pulled the clutch and she died. Did this a few times, finally got her to keep running with the clutch pulled by revving the throttle, if I let off the throttle she dies. When I pull the choke cable the engine seemed to run faster/better, but still wouldn't idle. I am guessing I need to do some carb adjustment but I wanted to ask for advise first...
I also suspect something is not right with my clutch. It is extremely hard to pull in, if I adjust the clutch cable as recommended (slight play before it engages) the engine never dis-engages. I am unable to dis-engage the engine by pushing on the clutch lever with my hands (which are pretty strong), the only way I was able to get the engine to dis-engage was by putting some pressure on the clutch with a vise grip and clamp down the cable with that tension. After that when I pull the clutch the engine does disengage, but there is still some drag on the wheel. When I dis-engage the engine and pedal I can hear spinning/rubbing in the engine.
I am wondering if there is something wrong with my clutch on this new engine? Something that can be fixed or is it gonna have to go back? I know there must be something wrong, cause you'd have to be Hercules to pull this clutch, most people wouldn't be able to do it. Also, I think the clutch cable should be slightly slack when the engine is engaged, no way I could do that and still dis-engage the engine the way it is.....
HELP!!! LOL
Thanks in advance for your advise
HELP!!! LOL
