First Cruiser build - Open to comments
Discussion in 'Motorized Cruiser Bicycles' started by MadC, May 17, 2010.
  1. MadC
    MadC New Member
    May 4, 2010
    69
    Hey Guys,
    Finally got my cruiser put together and I would like some helpful tips and criticisms.....
    [​IMG]
    [​IMG]
    I do need to tidy up the wiring tho.. Cheers
  2. dvddtz
    dvddtz New Member
    Feb 15, 2009
    162
    Looks great.Please keep an eye on that front fender,as the mounting tab is known to break.Fortuneatly for me I caught mine before it wrapped around the front wheel.Have fun.
  3. MadC
    MadC New Member
    May 4, 2010
    69
    ooo, grim mental picture...
    I was gunna change my forks to springers, any suggestions for customizing?
  4. hrichmon@gmail.com
    [email protected] New Member
    Sep 25, 2009
    117
    A little tip for the wiring... If you use zip ties, don’t tighten too much ... I prefer running the clutch and the throttle cables through the nice gaps between the gas tank mounting bolts and the frame.... holds it securely, and puts them in a nice approach angle to where they go on the motor.... also not tight, so they function.....
    ... also might want to tighten up your chain tensioner wheel (chain “looks” loose)... i like to drill a small 3/16” hole through the tensioner and the frame to keep it from moving...
    LOOKS GOOD.... hope this stuff helped
  5. MadC
    MadC New Member
    May 4, 2010
    69
    It sure did, I tightened the tensioner and I'll redo the ties, I did do some tie downs
  6. hrichmon@gmail.com
    Sep 25, 2009
    117
    those were just suggestions that worked for me.... if your tie downs work well and you like it... keep it..... in my experience it is easy to over-tighten and your throttle might not spring back anymore, or your clutch will be harder to squeeze.... also it’s easy to run it in pretty directions that will have you bending the cables too much causing the same issues... good luck
  7. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    if the chain idler is at the end of the adjuster hole ,you might remove a link
