max350
Got to ride it quite a bit today. It's 4 stroking almost all the time. New motor cleaned the ports, gasket matched intake and exhaust, high compression head, the rest is stock CG kit parts. Everything seems to work right just almost constant 4 stroking. i have tried every spot on the carb needle except full lean. Plug is stock but seems ok. Messed with the air screw a lot, seems to make no difference. I am going to start trying to read what i can find on hear, any suggestions where to start would be greatly appreciated. As far as the insulting posts I was not going to reply to the comments further, I have always felt if you argue with unintelligent people no one can tell the difference.
A good carburetor if you are replacing, is Dellorto 16:16 easy to set up
