This is a bike ordered by our local surf shop. They will add a surf board rack to it. It is pretty much stock from the box. Used the typical rag joint and all associated parts.
I used the SBP front U bolt mount. I upgraded the springer front suspension with all american bolts. The springer bolt was bought longer and I added a nylock to end of that. That fit well! The cross suspension bolts are upgraded as well. The upper fork bolts were exchanged from the standard zinc to "grade 5". Those bolts had a nylock added as well. As you can see I added a few mirrors. I needed to go to a thinner 415 chain bought from Pirate becasue of the beefy tires. I sprayed all gaskets with copper gasket as well as the head gasket. I also used some black RV sealant to the manifold where it enters the carb. I replaced plug wire and plug cap and went with a NGK B6HS.
All and all the install was a clean build all I really needed to do is cut the rear fender for clearance on the chain a bit. I did have a clutch issue as it did not disengage at first. However, after searching here I found that it was just grease stuck and broke that bond and she is good to go.
