Finding this part
I would call Lynn at MB rebel... They were shut down for a move... And there back up with a bunch of stuff...
The whole kit is available
I would call to make sure
VMB to the rescue!
Also Lynne at MBRebel in Greendale Wisconsin is good people. I live close enough to do face to face transactions. I have also done custom machining in trade for parts she sells.
The CMT baseplate is die cast with knit lines that fail. At least when used with a 212cc.
VMB's linked part is solid metal flat stock= very strong. I would use it.
Search ebay and amazon regularly never have done or looked at facebook would change sprockets cause I cant see aluminum lasting. That MB rebel one looks great now to find where they sell? and thanks to everybody helping;)
There on line and they moved from Wisconsin to Florida recently... They have more stuff than listed.... You can message Lynn via email link from the site
Decided I am going to go with the BMI plate although I really like the one from MBRebel its just way out of my budget. Now for the hard part and I am guessing this is kinda a question aimed at Sidewinder Jerry or anyone who knows gear calculations. Which gears do I need to buy for the rear of the plate?
My clutch is a 10 tooth and my 26 inch rim rear sprocket is a 44 which if needed changing I would do that to. Motor is 79cc predator to. Many many thanks to all that helped trying to find plate mission accomplished. PeteJ
@sportscarpat has built a ton of bikes using those gear reduction plates & different gear ratios... I'm sure he can steer you in the right direction. (^)
After a lot of searching and a lot of disappointment trying to find this plate for predator 79cc I have to turn to the big brains on here to find it or a better alternative.
79cc Transmission for Predator Engine - 4-Stroke – Kingsmotorbikes.com
Everywhere I check and anything I need is always sold out so any help would be greatly appreciated. Thanks PeteJ
I agree with you since I have been looking also for over a year now and gave up replacing the 49cc engine on a bike.
I replaced that bike with a Ebike and it appears most of the dealers are fazing out the gas bike kits and going to Ebikes.
