What I Have
Engine: 80cc Flying Horse Bicycle Engine Kit/BBR Silver
Carb: Nt Stock I also have HP Clone
Plug: NGK B6HS 7534
Bike: Black Zeda Bike
Pedals: Wide Crank Assembly 9/16 Pedals
ManiFold: 80cc offset 40 mm intake
Fuel Line: 3/16" Blue Polyurethane
Everything else stock
Fuel Type: 87 Unleaded
Oil Type: 2 Stroke Marine Grade
Oil Ratio: 16:1
Question 1: Can i use car oil if so what is the best oil to use
Question 2: what is the best ratio to use on these CG/HT engines
Question 3: i have to pedal quite a bit to get the engine to start even after priming but i have seen people able to just give theirs a tiny push or even a bump and some just spin the tire and let the clutch go to start it, how can i tune mine to where it starts this easy.
Also is there anything else i should be notified about to get more power out of these 2 stroke engines.
Plug: NGK B6HS 7534
Oil Ratio: 16:1
