SpeedWizzard
Made a heap of progress on the exhaust, figured out i'm going to mount it up front, cut off the stinger and weld the hole shut and make it a center bleed style. spent the last 3 hours cutting a section of 1 5/8" steel tubing. Only problem is, it doesn't fit on the damn exhaust outlet!!  can the outlet on the engine be removed? I was going to put it on a lathe and take off 1-1.5mm. Reason is i've already brought 2 different sections of pipe and i'll be mighty pissed if i have to buy a third. Thanks.  oh and sorry Easy, I should'veuploaded photos agess ago but got caught up with work. once i finish the pipe i'll take photos and upload them all.
Thanks
  can the outlet on the engine be removed? I was going to put it on a lathe and take off 1-1.5mm. Reason is i've already brought 2 different sections of pipe and i'll be mighty pissed if i have to buy a third. Thanks.  oh and sorry Easy, I should'veuploaded photos agess ago but got caught up with work. once i finish the pipe i'll take photos and upload them all.Thanks
