Exhaust tube bending
wret
355
65
28
Maryland
I tried out an idea for bending exhaust tubing with a pipe bender. I filled the tube with hardwood dowel pieces with a 1/4" hole drilled through them. The wood support prevents crushing the pipe. I got a little over aggressive and got a couple of kinks but nothing that looks like it would restrict exhaust flow.
The wooden dowel can be easily burned by injecting some compressed air and heating a section of pipe until the wood ignites. As soon as each piece looses a little diameter, they pop right out.
mapbike
5,502
109
Central Area of Texas
Looks like that worked out real good for ya, you can also leave a piece of pipe a couple inches longer than it needs to be, solder or braze a block off cap or plate on one end, fill the pipe with sand and then braze a cap. On the other end also, then you can bend the heck outta the pipe and it wont kink because the sand gets tighter inside as it bends and keeps so more pressure forcing outward in pipe that it holds it shape good.
Just wanted to add another way to do it here also wret, hope you don't mind and it looks like you wound up with a real nice looking pipe there.
Map
.wee.
wret
355
65
28
Maryland
I played around with some 3/4 conduit tubing to make a cargo rack. Using the sand filing method I got some crimping on about a 1.5 inch radius bend but not too bad. I really think could have tamped better though.
I tried the same bend with a dowel inside the tube and the tube crimped MUCH more severely. Sand filling is clearly superior.
mapbike
5,502
109
I'm gonna try hard packed in wet sand in some tubing when I have a chance, in my thinking the wet sand will pack in better, which should take more pressure before the pipe tries to kink in the bend area..... I may be completely wrong to think this but wet sand become pretty dense when it packs so this is my thinking.
Map
wret
355
65
28
Maryland
Wet sand "seems" like it will pack better due to the lubricating effect of the water. You actually don't want any lubrication when you do the bending. You want the grains of sand locked into an uncompressible matrix.
Also, if you use water you would limit your options for applying heat to the bend area.
mapbike
5,502
109
Lol.... water lubrication in the sand?
I would never need to use heat with sand in the pipe, heating the pipe would defeat the purpose and actually weaken the pipe and cause it to wrinkle at the bend point, wet sand is very dense and the strength of it will be that it will pack so firmly inside the pipe that the more the pipe bends the more outward pressure the sand will apply, this is ehat I think will allow the bend to be done with less chance of the pipe crimping at the bend, once I give it a try I will know for sure, but wet sand will pack harder and denser than dry sand and almost act as though there is something more solid inside the pjpe as it bends.
We shall see.....lol....!
Davezilla
2,705
10
San Antonio Texas
It looks like the sand method is good but it has to be tampped in there really good before attempting the bend. Wet sand might pack in better especially if you're using a much shorter section of tubing than that guy in the video, but worth experimenting with.
I was going to get some Cerro Bend stuff a few years ago but didn't really have an excuse to buy it but I've seen that stuff in action and it leaves no kinks or wrinkles, and it's ultra low melting point makes it practical for home use or smaller scale projects like these bikes' exhaust systems.
A while back I needed to replace some fuel line on one of my bikes and it takes a preformed hose with some really tight raduis bends in it, (dealer item only and Very expensive because of that) the regular hose would kink badly before going around the bends it needed to so I devised the idea to put a section of insulated 8 gauge solid copper wire inside the fuel line hose, then dip it in boiling water, take it out and bend to shape, let cool then remove the wire (wd40 helps a LOT here) and the hose held it's shape just perfectly.
This works best with those clear or transparent colored fuel line hoses and you can get the bend radius as tight as needed without any worry of kinking or collapsing.
I know this is off the real subject, but since we're talking about bending stuff without kinking it, it's worth sharing.... especially if someone has to route some 1/4" or 5/16" fuel line that needs a 1/2" radius bend and it keeps trying to kink shut. Hopefully someone can find this little tidbit helpful too...
curtisfox
6,077
4,041
minesota
Awesome! Thanks that is good to know. I could of used that a while back. I ended up making a full circle loop to avoid the kink.........Curt
wret
355
65
28
Maryland
I had some scrap tubing pieces so I decided to perform a little experiment comparing the tube bending discussed here.
Wooden dowel
Sand
Wet sand
Sand / Heat
Sand with welded bolts
Here are the bends:
CTripps
1,310
Vancouver, B.C.
A neighbour of mine mentioned that salt is also a good 'tube filler' for bending. He prefers it over sand, as he knows he can get all the salt out of the pipe with hot water. Either way, looks like a good way to go about bending conduit.
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
Depending on how you 'cap' the ends of your pipe, but if it is capped sufficiently to keep the sand from squeezing out, I'd suggest you don't heat wet sand.
Can you say, 'pipe bomb'? The steam that would be generated would make that a potentially dangerous thing to do. Even if it doesn't go 'boom' it might force the sand out under pressure. That could be nasty. Be careful, guys.
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Try filling a section with water and freezing it. Still needs capped ends but not sealed. Only one end needs to be sealed if you stand it up freezing it.
Caps still play a part in holding pressure as you bend, but if you can hold the column from popping out the end it works.
